302 351 Head Thermactor hole size?
Desert Thrasher
Are they all the same size thread, 5/8-11? I bought a set of plugs for the holes in the head. But they do not want to even start threading in. I know there are threads, I seen them before I installed the engine. Just wondering if different years maybe had a different size thread?
Viperwolf1
electron whisperer
5/8 11 is correct. The ford inserts are part #F4ZZ-6E086-A, but there kind of pricey now. I bought some recently and they wanted about $20 each.
Desert Thrasher
Desert Thrasher
I bought the Trick Flow ones from summit, they were $4 each.
Maybe I need to chase the threads with a tap, kinda sucks now that I got the engine in the bronco though.
I know I have ran across 2 different sizes over the years. One plug I pulled out of one head would not plug the hole in another head. Had to go to the store and buy a bolt to plug it.
Desert Thrasher
Desert Thrasher
Hmm, I think Ill get some 9/16 bolts and try them. When the engine was out I had a 9/16 bolt that did thread in, but it was about 4 inches too long. Then I read they were a 5/8-11 thread and figured that had to be correct. Oh well.
mattt
I went to the local McFadden Dale industrial hardware and picked up a pair of plugs for $2. Mine are 5/8-11. If you don't clean the carbon/soot out of the threads, the plugs probably will not go in. I had to clean mine to get the plugs in.
