302-351 Swap
broncosport
Knob Noster MO
Wondering what I should be looking for in a 302-351 swap. It looks like a easy swap but their is always somthing! The 351 is the high output 290HP 1983 or newer version. I dont know the exact specs?
wildbill
Old Bronco Guy
%) %) %) The only 351W that was 290 HP was the 69 motor it droped a few for 70 as the 351C came out at 300 hp. The 80's ho motors were about 150 hp. %) %) %) Bill :cool: :p ;D
74bronc
I believe when they call the 351W High Output, they are only talking about a 4 bbl carb. Don't look for any extravagent horsepower out of the stock 80's 351W. They need some healthy modifications to get up to the 300 HP range. I would be more concerned with torque out of the 351W rather than horsepower for a bronco.
70_Steve
Old Guy
Not sure what you're asking. Are you looking for information on the 351 swap??? Or specs on the 351 you've got? ?:?
marks77
B.G.,Ky
351 issues
Broncosport,
I will hopefully finish this mod today after starting it 2 months ago, b/c of school, work, & wife it took a little time. I put a 2" body lift to help clear the height of the engine. Some say you can put a 351w in w/o a body lift but it seems it would be pretty difficult. The issues I ran into were with the headers and the oil pan. I had a '95 motor with no EFI and only had about 1/2" to 3/4" clearance between the front diff and the oil pan, so I switched to the fox style pan. Solved that problem. I used Hooker header #6707 I think and the drivers side rubs a bit on the frame so I will bend out once it gets heated. I also thought the headers were too close to the porportioning valve so I moved that as well. I purchased the alt. & p/s conversion brackets from Wild Horses and that made things easier. I installed a universal radiator also which can complicate things a bit. If I can help anymore, just let me know. Good Luck.
ak68
Welcome to the list
If you haven't tried it yet there is lots of information on the 351 under the search function. Just type in 351w swap and see what you get. I hope you have fun working on your rig.
