302 Head difference
sburks737
I bought a 1970 bronco a few months back and it came with the original 302 engine and 3 speed tranny, also a "rebuilt" 302 enigne and another 3 speed tranny. (By the way let me know if someone needs one, I went with a 3550) I say "rebuilt" because I was told it was and it appears to have all new gaskets, water pump, timing chain, and paint job. Other than that I know nothing of the internals.
So my question...What is going on with these heads? I noticed that they have different size spark plugs, pulled the covers off and one is stamped with "A3B" and the other with "T". Is this legit? Can I run it this way (just have to buy 2 different size plugs)?
Im not much of a motor geek and really not sure what I am looking at but it seems... not right.
bmc69
Whew. That's a real junkyard rebuild, for sure...
The early heads have the large plugs...the small plugs came out in the 1975 heads.
The two different heads almost certainly have at least some difference in combustion chamber volume. Won't prevent you from running it though...the differences are probably not large.
jamesf7278
Salmon Arm B.C
if the earlier style heads are like the ones I just used they are closed chamber heads... if the other one is later its possibly open chamber, that's a pretty big difference in compression ratios from one side to the other? lol
jckkys
Looks like your talking about the date code cast not stamped between the push rod holes. The casting numbers are only visible with a mirror looking up from the lifter valley or by removing the heads to see the numbers. The '70 heads are 63cc and the '75-'76 are 58.2cc. and '77 up are 69cc. The 11cc difference between '76 and '77 combustion chambers is significant.
I would just run that bastardized engine as is while keeping an eye for something that hasn't had a junkyard rebuild to it.
In other words, if they botched the "rebuild" so bad to mix a set of heads I would not trust any of the other work that has been done. Trying to fix the mistake I would expect to find more and more mistakes. Cut your losses while you are ahead. If it is running now, just keep running it. There are plenty of good engines out there, and deals can be found if you wait for them. A small block ford is not an exotic engine.
S
sburks737
This engine was just rebuilt and hasn't been ran at all yet. I'm in the middle of a frame off so now is probably a better time to tackle it. Although not financially!!
Mtgrizzlymn
No way I would install that thing! I can't imagine putting money into a rebuild and doing that!
bmc69
So probably not worth paying to get matching head up to speed?
It might be...302 heads are dirt cheap used. (Which really begs the question on the overall quality of that rebuild..:-X)....
I'd tear it down and inspect everything. Might still have cylinder ridges and only got a "ball hone" bore job..might have excessive crank bearing clearances after some sand paper "journal polishing"...might not have had the cam bearings replaced..the usual laundry list of crude backyard "rebuilds". I've seen many of them over the years.
