302 modification question
It means that the cylinders have been enlarged from the standard 4.000" to 4.030" For performance it adds a couple of cubic inches displacment but not enough to notice.
It also means the engine has been rebuilt.
About the only downfall is that it is already bored once and if it needs rebuilding again, the cylinder walls may start getting too thin to bore it more.
It's nothing that will magicly add power or blow up. Almost standard pratice during a rebuild.
bmc69
It means that the diameter of the cylinder bores was increased (overbored) by .030" (from 4.00" to 4.03") It is only required when the stock cylinder walls have worn to the point that they are no longer tight enough to support/fit a stock piston. Replacement pistons can be purchased with .020", .030", .040" and .060" oversized diameters.
It's not a 'benefit/pitfalls' kind of thing..its simply a standard part of the procedure for rebuilding an engine, just like grinding the crank, or re-conditioning the rods.
bmc69
Once again I am shown to be the slowest typist on the planet...;D
Randomly press a bunch of keys then go back and delete the letter that shouldn’t be there.
