302 Roller motor conversion threads or reading or links
Mark
Bronco Klutz
NW Indiana
I have a blown head gasket in my 1980 block flat tappet 302, so what better time to change cams and convert to a roller motor.
I have shade tree mechanic ability, did convert my 302 to the late 90's Mustang EFI about 15 years ago myself with good guidance here on Classic.
Are there any threads or links or good reading on this? I'd like to get the heads (aluminum GT40 style?) with springs and such already installed.
'80 block, if it shill holds the '80 crank, will be the old 28.8 balance factor. The roller blocks are going to be 50 oz-in factor. That will play into it.
Aftermarket aluminum heads, so many choices. I think there are a lot better options than the aluminum version of the GT40. Depends on what budget you want. I was real happy decades ago with Trickflows, even later when I bolted on a set of cast iron manifolds they were still real good performers. I'm looking to do an engine next year for a completely different project and have some TrickFlows on the radar. Expensive, but complete with good parts installed. I've seen assembled heads (no rocker studs or guideplates) for hundreds less. Most every one of them is setup for a roller cam, or has a roller cam spring option. Most will do pretty healthy cam lifts as well. With a varity of chamber sizes for different compression ratios.
i would go find a foxbody mustang forum, loads info info out there.
I just see him returning with an .872" lift cam at 260/270 (at .050 duration) cam. The 8000-9500 RPM powerband is great.
I'm sure they have good advice, so long as you properly filter it for drivable power and not quarter mile power. I've seen way too much mustang tuning advice that is aimed at quarter miles times and nothing else.
Mark
Mark
Bronco Klutz
NW Indiana
I'm behind the times I guess. What option would be preferable to aluminum heads for this? I shouldn't rule out steel heads then. Something along the lines of Trick Flow twisted wedge heads?
And, I may be over my head here. I didn't think the crankshaft would be a factor in this. hmm
As for heads, I have not kept up to date completely either. There are a ton of options. From the varity of house brands that are mostly off-shore castings. And the still growing options from reputable head manufacturers such as AFR, Brodix, Trickflow. These top head builders keep refining the product lines. I have heard of no improvments in the GT40 line since it was launched decades ago. Do more research before locking in on a head. I have a trickflow picked for a project, but a lot of it has to do with chamber size and they offer one that will work for me.
As for crankshaft balance. The 302 (5.0 liter) is naturally an externally balanced engine. That is some of the counterweight that is normally part of the crankshaft is actually in the damper and flexplate. It is a way to help make a compact engine. In 1982 Ford did a redesign of the 302 crankshaft that required more counterweight placed on the flexplate and damper. Less counterbalance built in the crankshaft but to keep it balanced, the weight is moved outside. For all general purposes of a production engine, it works just fine. But mix parts across that change, you have an engine with a severe vibration issue due to miss matched counterbalance. When the change was made, no other changes were made to prevent the interchange of parts.
