...I will look into the Explorer setup you mentioned
Get 'em while they're still readily available at the junkyards. Or the easiest (and sometimes even the lower priced) way to get a full setup is to talk to member sandmann here (others can confirm if I've got the member's username correct) and have him ship you one.
So far everyone that's bought a setup from him has been very happy with the purchase.
I'm not sure the headers will work yet. I'm thinking they might interfere with my clutch linkage...
Generally speaking, if they're not Early Bronco-specific headers, they won't work.
And it's not the clutch linkage that's the main culprit, but the passenger side frame rail.
Mustang headers almost never work, nor do most of the car chassis headers vs the Bronco headers.
But there are one or two models out there that people have found to work, so they do exist. Headman Elite mid-length headers I want to say, but not sure. I sell headers made specifically for most Bronco/transmission setups, but nobody's arguing that Mustang headers are cheaper. Just that they don't work very well in 90% of the cases.
what do you think about the other parts?
As mentioned, as long as the distributor has the correct gear for your type of cam and is for a 302 and not a 351, you should be good to go.
The coil #45011 should be fine too, but you would do well to confirm it's internal resistance and which setups that Pertronix recommends it to work with. Meaning whether or not you will still utilize the factory resistor wire, or run the full 12v all the time. This is important, but I don't remember which coil has which rating. It's spelled out pretty well in their catalog.
I didn't even look at the wires, but as long as they're suppression type wires and sized for a 302/50 you're good to go.
Usually...%)
I am going with a 3 1/2 suspension lift and a 1 or 2 inch body lift. Planning to run 35" tires.
Personally, and most here agree, the 1" is better than the 2" unless you just have to have 2. It looks better on Broncos because there is less gappage between the bumpers and the body, fewer items to modify to work with the new body height, and it's less expensive too. Which is not a bad thing sometimes.
Clutch and trans and transfer case linkages, radiator shroud, even sometimes fuel filler hoses (but rarely even with a 2") need to be looked at closely, and usually modified.
Plus you don't need that much to fit 35's under a Bronco. So keeping to the minimum needed is what some like, where others like the larger opening in the fenders above the tires and the taller overall look.
Are you going to leave the fenders cut way up like that? Or put them back to stock, or something in between?
I'm thinking that with that much metal cut out, 35's are not going to be an issue.
