I am helping a friend with a 302 , motorcraft 2 Bl. You have to give it gas to keep it running . Runs very ruff . Then will die . The vacuum will hardly build at all . I have timing close but since it won't idle I did the best I could do . Carb adjustment screws are set at base 1 1/2 out. Even when you give it gas and try to keep it running the vacuum is very low.
My plan is to do compression check to start
Any other things I could look at ?
The carb had some vac ports not connected , I capped them off . I'm not familiar with that carb are there any vac ports I should make sure are hooked up?
He does not have a PVC going into his valve cover .. Could this be a issue ?
He bought it as a project so it has not run right since he owned it
