302+water pump bolts
bamabaja
The Shoals
Anyone have list of size bolts used to mount 302 waterpump? Several kits out there but poor reviews on most for fitment issues. And pricey for bolts and studs. Thanks
chuckji
SE Michigan
Piggybacking on this post, hope you don’t mind bama.
I bought alternator and power steering pump brackets from CVF Racing and before I get myself in too deep, I wanted to see if I could get some info from you knowledgeable folks.
I’m wondering (worried) if any of the bolts I need to remove/install go into any water jackets. I’m hoping all I need to do is remove/install the necessary bolts from the water pump. If any go into water jackets, I might just put off the whole project. The bolts in question are circled in red.
Engine is a Blueprint 306 cu. in. Bronco Special (302)
Thanks for any and all advice.
bamabaja
bamabaja
The Shoals
No problem Chuck. We are dealing with same BP 306 issues. Really don’t understand why BP doesn’t provide bolts, or provide for purchase that I found. Even when purchase BP serpentine kit, no bolts. I have found BP helpful and responsive, but little things, forgot dipstick, etc. Removed after dyno test ?
Promptly sent one upon request. Will keep u advised.
chuckji
SE Michigan
Hey Bama,
Sorry to hear your frustration. My engine is all put together, but I’m thinking to spruce it up a little what these mounts. Plus, the easy alternator tension adjuster is a plus.
Hang in there man, you’ll love the engine once it’s done.
