306 EFI computer Gurus needed pls
blazinchuck
blazinchuck
In the thread title you ask clutch fan or Taurus? Taurus all day long. Much better cooling and couple of horses to boot.
i hear ya...and id really like to do it. i guess im always looking for the better route down the road. i worry bout using a "used" elec. fan...and to be totally dependent on one that cant be easily replaced if it fails?:?
so because of this...im leaning towards the clutch.
theres a good thread on pirate bout the taurus fan and another version from a volvo...that seems to be perfect!! i might try to locate one of those. its just like the taurus but the fan is completely removable from the stock shroud. so that gives you the option to build a custom thinner shroud and have the awesome 2 speed fan to boot.
heres the Taurus fan option
right now i have a 12 pusher in front of the rad that has a thermo probe in the radiator to turn it on and off. with the BCB fix fan..it hardly ever comes on. if i did a elec. fan, i might go with a screw in temp switch for the water neck.
on another note...the guy hooking me up w/injectors decided to keep the rail...since he's worried about the same issues i am. so i guess ill hit the LKQ again this weekend to grab another rail. all the explorers out there were '97...hope thats a good rail like broncoitis mentioned
broncoitis
thanks broncoitis...i cant get the explorer rail, and i think i will have to use it. sucks tho...my HP pump is on the dr. side fender well, so thats means i'll probably have to reroute the fuel lines.:mad:
thanks for the pic, now i can see exactly where the new ones will come out;D
Lemme know if you can or can't get the rail! Im sure one of the junkyards up here has one that shouldn't cost too much! %)
blazinchuck
blazinchuck
actually...im off tomorrow. i know last week there were two available. however, tonight before our bronco meeting...i looked at the t-bird rail and it looks better than the mustang rail. i got my new injectors tonight...so tomorrow i will test fit everything, then go to local junk yard to get explorer rail if i need it. but, i really thing the t-bird will work. the t-bird pressure side comes out 90 degrees compared to the mustang which is at a angle(toward alt)
blazinchuck
blazinchuck
ok, well...got up today to run a few errands and had a vibration round 30-35mph. just what i thought! a dang u-joint. so, i had to fix that before starting on the motor again.
installed the new injectors and t-bird fuel rail...everything looks good so far. doesnt look like there will be any interference with the pressure side fuel line and the alternator.
i slipped the distributor in place to see how much of the bracket needs to be clearanced. how have you guys had to remove??
also, one other problem i found. when i got this gt40 intake(it didnt come with any bolts) so i pulled some bolts the last time i was lkq. the bolts came from a 97 explorer(so you would think they were perfect) however, i found the bolts are tightening down before the intake is??? its not by much, and i threw a washer under the head of the bolt, but the name plate wont bolt up right because the bolt heads sit up just a hair.%)
here are a few pics
blazinchuck
blazinchuck
also, any advantage in using the explorer throttle body vs. mustang? and any problems when using the explorer(ie. throttle cable, return spring, etc.)?
ilovemaui
Pacific Moist West
The way mine is set up I could swap it out in about ten minutes with either another Taurus fan or the clutch fan. Four 7/16th bolts and crew the clutch back on. I have three spare T fans if I need to swap it out.
ilovemaui
Pacific Moist West
As for the distributer, I stabbed mine one tooth back to avoid hitting the bracket. On the intake bolts I reused the ones from the mustang engine with no issues. I did have an issue with the upper intake bolts being too short for the phenolic spacer so I had to search around to find some longer bolts. I ended up fabbing one of them by welding a nut on a piece of all thread.
broncosbybart
You will need to use the explorer TB with the 19lb injectors. You will also need to source a 70mm MAF. PM Viperwolf about it. I can't recall the part #'s. I got one off of a Crown Vic. These MAF's are VERY hard to find (at least here in charlotte). Had to modify the TB for the throttle linkage. I used BC's kit. It worked well. Either look up Tito's build here or look at my build on CB4x4. I think I showed how it all went together.
blazinchuck
blazinchuck
if thats the case, i may not mess with it right now. i dont need to over complicate things right now. i need this to go as smooth as possible. no reason i cant use the mustang TB...it came with 19lb injectors anyway. seems like ya have to modify the explorer TB shaft...ill try that later.
if things work out, i might try swapping engines this weekend coming
blazinchuck
blazinchuck
well, that sucked!! FML...just pulled everything off the front of the block. i really had no idea if the cam shaft bolt was clearing the explorer cover...now i know!
and in the process of removing the timing cover, i just so happened to completely destroy the brand new 1 piece oil pan gasket:cry: another $30 down the drain.
guess i need to grind the bolt now and buy all new gaskets%)
Viperwolf1
electron whisperer
Just grind off the castle portion of the bolt. I wouldn't replace the washer with anything thinner.
Timing chain looks kind of loose.
blazinchuck
blazinchuck
i still need to post post some pics...
but, a quick run down...
Fri: removed engine,tranny,exhaust,drive shafts
Sat: installed 306 and nv3550
Sun: finished swapping parts from stock 5.0 to 306. got everything back together to fire it up and had no luck cranking it. we checked timing many times...in the end found 5 or the 8 NEW injectors were not firing. we replace them with the stock 5.0 injectors and she runs awesome...
quick vid http://www.youtube.com/watch?v=Z7VPBH0yllY&feature=youtu.be
BucknEB
Johns Island, SC
Aside from the bad injectors, I'd say we had pretty good luck on this swap. There's nothing better than hearing that engine fire up after a long weekend of wrencking. I can only hope that my EFI swap goes half as well. Thanks for letting me test drive it! :cool:
Here's some pics I took this weekend.
Bronco Biff
I HEAR YA!! Looking good, Chuck! Got that sound ya craved, huh?! I'm going to have to show my wife the video just so she can see her favorite "If your Skeered, say your Skeered" bumper sticker.
blazinchuck
blazinchuck
yeah man...very please with it now! ive been trying hard to get that "mustang 5.0 sound" theres nothing like that sound of a stang leaving a traffic light...
it all works perfect with the new 5sp i swapped in a few months back.
im a happy camper!!!
KyleQ
You can't have too much of a lopy idle with EFI, if you get intake pulses at the MAF the computer will constantly adjust and it won't like to idle from it. I hope it will be ok for you on the trail, shouldn't be too bad on the road.
I looked at your cam and what I'm going to run, COMP Cams 35-518-8, and on a TFS 185 TW headed 351W mine isn't that much bigger. It should be fine - and fun :D
blazinchuck
blazinchuck
well...all i can say is the ride into work this morning was awesome!;D
guess i forgot to turn the nice stereo on...musta been enjoying the great exhaust notes being played:cool:
temp held a perfect 195*...hope that holds true in the warmer days, well have to see
blazinchuck
blazinchuck
thing were going good until yesterday. riding home and stopped at the gas station. went to restart the truck...turns over, but no fuel pumps. begin swapping relays, checking fuses,check wiring to pumps. call chuzie for more ideas...decided to do a "self test"
computer wont do it! my check engine light was getting dimmer each time i tried to selftest. i put the pumps on run, by grounding the test port out...the pumps are running, but it wont start(like ignition isnt working)
called Doug, and he brought me his computer (from the efi swap he plans to do) plug his computer in and it fires up. guess i get another computer
