32 inch tires with 2.5 inch lift
NolaBoy
Ok. I've searched the forum for awhile now. I've found lots of pictures of 33/12.5/15 tires (which I'm currently running), but haven't been able to find any pictures of 32/11.5/15. I am trying to decide on the two (Most likely BFG All-Terrains) and was wondering if anyone had any pictures with this setup. I have a 76 with the fenders cut. Thanks!
Jimmy
rguest3
You can install a fairly tall tire with 2 1/2" suspension with fenders cut. 33s (32-32.5" when measured) fit with just cut fenders.
Here is a picture of my 71 Bronco with a 2 1/2" lift and cut fenders. Installed are 285/70R17s (which are taller then 33/12.50/15s)
I would go with at least a 33/12.50/15 or a 33/10.50/15.
mustanggarage
off topic, but I like those wheels
Vicki
Newbie
Our '73 w/ cut fenders and 2.5" lift
We're running Nitto Mud Grabbers 33x12.5 R18LT
nsiti
Newbie
I have this exact setup (32/11.5/15 with 2.5 inch lift) and think the stance looks excellent. A nice balance between classic and modern, and not too aggressive. I just installed new BFG AT KO2 tires and Mickey Thompson Classic III polished wheels which really worked well together. You can see a photo in my garage (with old tires and wheels). Unfortunately, I don't have any new photos as the Bronco is undergoing a restoration at the moment. I'm expecting some in the coming days/weeks, which I will come back and post. Good luck.
N
NolaBoy
Thanks for the replies! Look forward to seeing the pics nsiti. I have seen I can go bigger with the tires but very interested in the look of the 32's specifically. Anyone else with this setup?
mudstud
Bronco Bonehead
Excel
32X10.50X15 no lift.
triracer67
33x10.5
Take a look at my garage, I have the same set up. Also, the lift is old, and probably sits a little lower, especially with 351 in front. I recently got new 33x10.5 and have zero issues.
JGbronc
Bronco Maniac
32x11.50 with Wild Horses 1-1.5" front coils and stock HD rear springs.
lonesouth
32x11.50r15 on 1978 dish bullet hole wheels, 2.5" lift, maybe a 1" BL.
kylakekevin
32x11.50x15 on a old Duff 2.5 lift. not the best pic though. I will be going to a 33x12.50 soon I hope!
mudstud
Bronco Bonehead
Excel
Offset I believe 0 offset
15X7
No rubbing
The bronco is going back to an uncut.
