351 Lightning engine
marklc
Just want to double check as I am barely scratching the surface on understanding the whole fuel injection thing. Anyway I know a 351w out of a truck is too tall for an early bronco. But then I read where an intake from a ford lightning is lower and will work. My question is I have an opportunity to purchase a 92 351w lighting that has a 5000 mile rebuild on it and want to know if I would have to change anything on the intake portion or would it be low enough as is.
backpain
I don't know about exact EB fitment, but 351w Lightning short blocks are a good starting point for lots of projects. You can always make some other intake work on that long block. Prob has electronics you want also.
Are you willing to do a cowl hood?
gtnorga
I want to do the lightning style intake and electronics too for a 351.
I read somewhere on here that it clears fine if the body bushings are pretty new.
I read somewhere else about motor mounts to allow the engine to sit lower.
I think it was one of the mustang forums.
jkransbottom
Stallings, NC
I was just reading the very same thing about the motor mounts allowing the engine to sit lower. It was in the Tech Articles on here. Really good one about swapping in a 351W.
Viperwolf1
electron whisperer
You'll need 2" of body lift with stock motor mounts and a 351w lightning intake if you want to use a stock hood.
Nightstick
Bronco guy
Are you sticking with the speed density of switching to mass air EFI?
Viper, do you mean lightning lower and upper, or just the lower with an explorer upper? I have read that the latter wouldn't require any body lift (I'm doing a 1" anyway to clear my tranny).
Viperwolf1
electron whisperer
I'm 100% positive a lightning lower and explorer upper won't fit with a 1" body lift. Just tried to fit the hood on one today. It needs about 1 more inch. I don't think the lightning upper is much different.
Lightening upper is a fancy version of the Explorer upper. Explorer upper is often speced out as it flows almost exactly the same as the Lightening upper but is a lot less expensive.
My measurements a few years back, 1-¾" of body lift needed, so 2" would be the common size. Although with the right hood you should be able to get by with no body lift.
Now for the rest of it. The ECM also runs the trans. Leave the trans out, expect codes. I have heard that there may even by some drivability issues as the engine will pull timing when it thinks it is time to shift, even if you are not ready to shift. Sorry, the trans is a little too long to comfortably fit under the Bronco. Then there is the little issue of the ECM looking at vehicle speed for shifts and being in low range will confuse it.
But don't be discuraged, I like the lightening motors. Great base and good starting point. Like most any modern swap it has a handful of little issues that need attention.
M
marklc
I am using a 2" body lift because i planned on installing a ZF. I think I'll use the motor but turn it back to a carbed engine. Think I'll save myself a lot of time and frustration. I think the EFI thing is just a little over my head. Thanks for all the responses fellas.
Nightstick
Bronco guy
Guess I'll be doing a 2" then, but don't really want to %)
I read that cowl induction hoods make the engine run hotter, true?
SSDDBRONCO
Los Angeles
Well if you make holes for the hot air to escape the from the engine bay it would not make the engine run hotter. But if it is stock with no holes then im not sure but the cowl induction hoods are bad ass;D
Nightstick
Bronco guy
That makes sense, and I too had the same thinking but I thought I had read on here that the opposite is the case. Apparently my memory is dyslexic.
I read a few threads on a hot rod site where a couple guys were arguing about the effectiveness of cowl induction hoods. The short version is they work, but are intended to be a forced air system where the air filter (carberated engine) is sealed from the rest of the engine bay which at higher speeds forces cool air into the engine, and at low speeds acts as an exhaust for hot air.
Sounds like a $500 "upgrade" that isn't very effective for our rigs.
Viperwolf1
electron whisperer
Put a remotely operated flapper valve in the cowl hood and you can have the best of both worlds.
RustyShackelfor
Centerville, TN
if you decide to do this, pm me and i may take the intake.
COBlu77
Arvada, CO
Ditto. I have a 351W with a Lightning lower and upper intake and am using the stock hood. I tried a 1" BL, no go. 2" BL clears just barely.
SSDDBRONCO
Los Angeles
Can you post some pictures i want to see how it looks with the lightning upper intake. Haven't seen to many if i am thinking right ;D.
COBlu77
Arvada, CO
There are two pictures of my engine on the last page of my gallery. I'm not near the computer with the actual photos to post hem directly.
Nightstick
Bronco guy
Can someone tell me what the height is from block to the top of the plenum using a lightning lower and explorer upper, thanks.
