351 w swap
BroncoRachel
I need some help from who all has done the 351 Windsor swap. I have a 68, they went to put my 351 w in today and the motor mounts don't line up with the engine perches on my frame. is this typical? fix?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
351W will line up exactly with a V8 frame Bronco.
As stated, if your Bronco was originally an inline six, the engine mount towers are completely different. The six cylinder towers will need to be removed and correct V8 towers welded on in the correct locations.
71 CA Bronco
Could the motor mounts be reversed? I can't remember what they look like.
blubuckaroo
Grease Monkey
Ridgefield WA
It may look like it won't work if the motor mounts are bolted to the frame or engine when installing the engine.
I had that issue once, but now I just drop the engine in and put the mounts in once the engine is in place.
It's much easier that way.
Apogee
Tangent, OR
Just to ask you dont have a 351M do you?
X2...and do you know how to tell the difference. Does the engine you have fit the Ford small block bellhousing pattern? FWIW, the 351M/400 engines have the same pattern as a 429/460 and look completely different from a 351W.
hucktruck
Missouri
Curious what motor mounts you are using. I had an issue with one of my Wild Horses heavy duty mounts. Bad batch maybe cause I had to modify it to make it work.
If the engine is angled back too far (transmission too low) the valve covers will hit the fire wall before the motor mounts line up. Take the motor mounts off the engine. Get the engine in place. Install motor mounts one side at a time. Once the engine is at the correct angle everything will line up.
Same thing also happens to a 289/302 but with a shorter deck it is more forgiving, but still happens.
