LowCountryEB
Currently running:
1974 Bronco (302)
NP435
4:11's
35" Tires
3" Susp. Lift
2" Body Lift
Block:
What is the best year block to buy? I have read a lot of good comments about the 69-74 351w's due to their additional mass. But have also read that these blocks are problemsome when using for a stroker motor, and the deck height may be too low. What year should I look for? If in a yard, what kind of truck/van should I look at?
What I want:
I want a high torque (stump jumper) motor at lower RPM's. HP too, but torque is more important. I want awesome numbers, but also want the motor to be reasonably priced to build, dependable, and reliable. I want the motor to last 75k+ miles (4-5 years) at least. My bronco is a weekend driver. I'm not looking for a drag car, but I do want to be quick and fast out of the hole.
I have done a lot of research about the 393 vs. 408 scenario, but want to ask BRONCO owners their opinions.
Parts: (and read comments below)
Stoker Kits
Pistons
Heads
Camshaft
I have read a lot of good things about the Eagle stroker kits. Is this the most reasonable, and best kit for the money?
What about the pistons? I have read a lot of good comments about the Keith Black pistons.
Heads? How about Edelbrock?
Camshaft? What is a good 4x4 mid range cam?
If anyone has a good build spec sheet they can email, that would be great. Please let me know. I appreciate your opinions.
1974 Bronco (302)
NP435
4:11's
35" Tires
3" Susp. Lift
2" Body Lift
Block:
What I want:
Stoker Kits
Pistons
Heads
Camshaft
