All--
I am replacing the cam on my 351W (69 or 70 block per the PO) and doing the explorer serpentine conversion and I wanted to replace the timing chain at the same time. Looking at the timing chains online and they have two different versions, one for a 1 piece eccentric and another for a 2-piece eccentric. Given I'm going to have to delete the eccentric for explorer w/electric fuel pump does this really matter? I believe my earlier block must be the one piece if it does matter, can you confirm?
Also, while searching online I saw this:
Two different length dowel pins were used in the front of the cams in 221-351W engines. In 1972 and earlier engines, a longer (1.375”) dowel pin was used so that it would extend through the one piece fuel pump eccentric used on these engines. The 1973 and later engines utilized a two piece fuel pump eccentric which required a shorter (1.125”) dowel pin. If no eccentric is used, a thicker than standard retaining washer must be used to make up for the thickness of the eccentric. The cam gear MUST be pulled tightly against the snout of the cam. If the gear is not tight against the step at the front of the cam the bolt will come loose and engine failure is sure to occur.
If this is true, anybody know what washer is the right size?
Thx much
Thx much
