stoker
- Aug 28, 2011
- 127
I am building a 351W to replace a tired 302 in a 73 EB. It is fitted with: Top-Loader 4-speed transmission, 4.11 ratio rear axle with 33” tires. Local engine shop is recommending an Elgin E-1790-P camshaft. Will be mostly street use with moderate off-road, nothing extreme.
Intake Lobe Lift: .303
Exhaust Lobe Lift: .303
Intake Duration @ .050”: 216 degrees
Ehaust Duration @ .050: 216 degrees
What are your opinions on these specs? Elgin describes this class of camshaft as follows:
Fair idle quality with lope. Good mid-range torque and response in 2400 - 3200 RPM range. Operating power range 2000 - 4800 RPM. Good fuel economy cam with correct equipment. Good choice for light towing. Compression 10.3 to 1 or less. Will work with stock or slightly modified engine, stock automatic or manual transmission.
Any advice appreciated.
