I'll be curious if you can get the Explorer fuel rail to work with the distributor on the 351W. I had an interference fit on mine (5.0) and had to keep running the Mustang rails. It seems to be a common problem based on a number of posts on the interwebs.
Todd Z.
I just went out and test fit my motorcraft dizzy on my Edelbrock 3880 (now replaced by 3884) intake with the Explorer rails. There seems to be plenty of room, maybe because the 5.8 is wider? In my picks I used a heater tube from a 86-93 mustang as the explorer tube put the coolant temp sensor hitting the intake. I did bend the heater tube to water pump down a bit as it’s meant for the 5.0. I’m also using the Explorer front dress with the Saginaw bracket from wild horses like you, without the AC pump.
Kyle
