casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
I have been running the relocation brackets for my P/S pump and alternator on my 351w conversion for close to 15 years. I have never had a problem with it other than thinking it looks kinda half assed. Now with my 4x4x2 rock crawler power steering conversion, my clearance between the steering box and the pump pulley is a matter of a couple millimeters. My first thought was using a slightly shorter belt to gain a little clearance but now I'm thinking about getting some 351W accessory brackets instead. Any suggestions about a good donor? I'm not looking to go serp. I just want a better v belt setup. Also, I plan to get a vintage air setup in the not so distant future so I need to think about how the A/C compressor might fit into this setup as well. I think I'll do a little junkyard research this weekend but I would like to have some ideas/suggestions before I start a blind search. Also, I'm not opposed to a serp setup, I just figured v belt would be easier so if you have a good serp donor for a 351 I'm all ears.
