70EB
After an enormously long time in the making, I finally heard the beast roar to life today at 1600 (4 pm for non-military folks).
The procedure would have been comical to watch. Everything hooked up, the key turned to "on", wife, with one hand grounding the fuel pumps at the test circuit, somehow holding two fire extinguishers at the ready....fuel pumps engage and I am running around and rolling under the truck frantically searching for high powered fuel leaks, images of a massive fire in the back of my head.
Whew, no leaks....now on to phase two. Start the truck. It comes to life....and then stalls. Try again and it runs a little better.....must be the computer learning....idles settles down a little and it stays running.
It smells bad! Remind wife that it is not running rich, I'm too smart for that.....ah, yes, the new BCB headers and exhaust are burning off there coatings.
I let it run for awhile checking the temp and fuel pressure, looking (albeit less frantically) for leaks...idle gets a little better.
Initial observations:
1. Fuel pressure is 34psi at idle, rock steady. Should it be higher?
2. Idle still lopes a bit. I do not have an agressive cam at all, should be rather mild. Probably still the computer learning.
3. Codes that I pulled are 81, 82, 84, 85 which should be normal with the RJM harness.
4. HP fuel pump had no issue drawing fuel from the tank (WH 24gal). Took about 10 seconds on initial priming to get 34psi at the rails.
5. All the injectors are firing. Heard them ticking using a metal rod.
Still left to do:
1. Get O2 sensor bungs welded in. Can I drive, as is, for a few miles to get to a shop without them?
2. Finish hooking up the BCB EFI throttle cable. I hate cutting the cable and getting it to go into the little end bracket thingy, always fray the cable (from doing this on the carb throttle cable).
I want to thank alot of people for their assistance with questions from this board (saddleup, Nickstrix, Labbster, etc)
Pics are from today.
Previous threads:
http://classicbroncos.com/forums/showthread.php?t=80131
http://classicbroncos.com/forums/showthread.php?t=79114
Bill
Still left to do:
Previous threads:
Bill
