3g wiring???
NYLES
Red w/black stripe wire where does it go? Its currently wired into my RJM harness but that's about to come out, I just need to know where itll need to go when RJM efi harness is removed.
Viperwolf1
electron whisperer
Stock red-black wires are brake light switch and low beams.
NYLES
NYLES
its coming out of 3g alt and connected to green wire on RJM harness.
NYLES
NYLES
It might be a green wire going to a red/b, into RJM harness if so no problem. Its the only small wire coming off the 3g, Its RJM#26 alt power goes to key to run so I guess itll go to power on switch?
Viperwolf1
electron whisperer
The green-red wire used to go to the old voltage regulator. It's 12V with the key on.
NYLES
NYLES
Thanks! ....................................
NYLES
NYLES
VW So when I remove the RJM harness this green/red striped wire needs to go from alt to a 12v key on source?
Viperwolf1
electron whisperer
I suspect the red-black wire you see is tied to the stock green-red wire from the old voltage regulator. If that's the case, it's already connected to a switched 12V source and you would just have to connect it back to the alternator.
Steve83
You need to clarify which side of the Gn/R wire you're talking about; the side coming from the 3G regulator, or the side coming from the Bronco?
And which Bk/R; circuit 26 Bk/R that goes to ground where the original regulator was, OR circuit 38 Bk/R from the starter relay to the alternator Y charge wire?
NYLES
NYLES
Green/with stripe coming from ALT, (forget black n red, my bad) Now its wired to a single green solid in RJM EFI harness, I will be removing for Fitech EFI, I'm pretty sure its gotta go to a 12v key on?
Will be wiring back into a 4 wheeling junky harness which I cannot find the diagrams for?
