Hi,
Well my two cents is keep the rear drums.
Yes, rear drums aren't as cool as rear disc but I've had bad, bad, bad luck with my parking brake and I've adjusted the snot out of those rear discs.
Problem; drive hard it hard, heat up those discs, park on a hill and my Bronco creeps a good 5 to 10 feet per hour and the hot rear discs get warped too easily when the parking brake is engaged.
NOT COOL. After the discs are warped you get a slight thumping feeling in the pedal, similar to a bicycle rim when not 100% straight.
IF I COULD DO IT AGAIN, front disc, hydro booster and rear drums. Sure, rear drums aren't as easy to replace pads when you do a brake job but if you want an easy car, get a frack'n Prius.
Anyway, good luck with your build!
