4 wheel drive question...help!!
fatboy4211
Ennis, TX
I went to my land to feed my cows a large round bale. It was still muddy from the previous rain. As a precaution is locked in the hubs to keep my boots semi dry. I went thru the muddy spots with no problem...so I thought. When I pulled out onto the roadway and went down the road I felt as though I was sliding sideways on a curve in the road. I got out and checked for flat tires. Further down the road at a left turn I realized that I left the hubs locked in.
The real problem is...I never switch the gears to engage the 4 wheel drive. According to the gear pattern on the shifter knob, I should have been in two wheel high. Am I missing something. This is my first 4 wheel drive that isn't electronic.
broncnaz
You could have a traction device in the front end that would make the front want to slide as both tires are trying to turn the same speed. Of course you do need to figure out if its in 4wd or not as well since you dont seem to be real sure.
That's what I would think too, from your description.
If you still have the axle I.D. tag under a bolt, look for an "L" in the numbers denoting the gear ratio.
gearida
Newburgh, IN
If the hubs are locked, then you are turning the complete differential, it is just not being driven from the transfer case with power. You may feel some drag from your gear ratios being slightly different front to rear and drag from just the rotating assembly.
fatboy4211
fatboy4211
Ennis, TX
Is the 4 wheel always powered up. I thought that the 2 high completely took out the 4 wheel drive.
Scoop
Bronco Old Fart
Cuchara, CO
In 2 high the front driveshaft is disengaged. From the description you give I think you are still in 4WD. Can you unlock the hubs? If you cannot unlock the hubs as it sits then your are probably in 4WD and are binding a bit. Easiest way to unbind it is to jack up the front - that should release the bind and let you unlock and shift it back to 2 high. Or find a gravel road asap and drive it in reverse a few feet.
fatboy4211
fatboy4211
Ennis, TX
the hubs unlock easily. the loping (when in 4wheel and in a turn) stops after i unlock. i was very surprised when the 4 wheel kicked in just by locking in the hubs. i figured that when i got stuck i could engage the 4wd high.
im just guessing that the 4 wheel drive is contant and causing wear and tear without the need to. everything appears original underneath. i would like to stop the fulltime 4 wheel drive without removing the drive shaft
SDlivin
San Diego
What type transfercase shifter do you have? the T or J style?
It appears that your TC shifter is engaged. So you are correct, you are in 4wd at all times, but it only is working on your front when you engage the hubs, and also correct you are usings things in the front axle you don't need to when not using 4wd.
fatboy4211
fatboy4211
Ennis, TX
stock shifter. according to the vin plate i have 3.50 gears, trac-lok rear 2780 lb axle, with power steering and limited slip front diff
im not too smart on these things
desertoasis2b
unlock the hubs have someone drive it while you look at the front drive shaft
if the driveshaft turns your in 4x4 if not your in 2x
Scoop
Bronco Old Fart
Cuchara, CO
First, what year is your Bronco? 73 was the transition year. Early 73 and prior had "T" shift TC's where the shift lever has a T handle and what looks like a automatic tranny shift gate - the shift pattern is a straight line. Later 73's had the J shift TC which has a round knob on top of the lever, a rubber boot at the bottom and the shift pattern is a reverse "J".
(Except if you have a 66 (!) it will look like a J but shift like a T and is considered a T.)
broncnaz
Since your VIN tag say you have a front Limited slip and you can unlock the hubs easily I would bet that thats the issue. Even without any power to the front wheels a limited slip or locker can make the front end push on slippery surfaces
Easy to tell without resorting to a helper driving while you look. Instead, with it in 2wd and the hubs unlocked, just reach under and try to turn the driveshaft. If it turns easily, you are indeed in 2wd, your transfer case is functioning properly, and you don't have full-time 4wd.
What they were saying, and broncnaz just said again, is that with a limited-slip, there is always some torque-bias (probably not the correct term here, but will suffice for now) between the two front wheels when the hubs are locked. Doesn't matter that no power is being transmitted from the transfer case to the axle, there is still a connection between the two sides, and when you steer into a corner, one wheel by necessity must turn faster/slower than the other. So you get weird steering feel. The limited-slip is trying to do it's job and keep both wheels connected and running the same speed the best it can.
Your idea of locking the hubs ahead of time is fine. But for now, lock only one hub. Run around with one hub locked and the other unlocked. When you need 4wd you shift the t-case like normal and still have a little extra use of the front end. Without all the drama associated with a limited slip that you're experiencing.
And yes, you won't have the full benefit of all four wheels spinning, but at least you'll have three. And in the snow/ice, sometimes having all four pulling is not the best, most stable way to get around.
If you get in deep, and just have to have the extra wheel working for you, simply lock the other hub in and away you should go.
In theory...;D
fatboy4211
fatboy4211
Ennis, TX
hey!!! i spent about 20 mins on it trying different positions. finally i hit it right. im now in two wheel drive!!! i can turn the front drivershaft just like you said.
i took it out for a spin and wow! not as noisy, smoother steering, just all around BETTER!!!
you guys are what make this website fantastic!
So you can hear all the other noises now! Yeah, a gear-drive Dana 20 is pretty noisy in 4wd. Either high or low, but you notice it more in 4-hi than anywhere else.
Straight-cut gears will do that.
Glad you got it figured. Do you think your linkage needs some adjustment? It shouldn't be that hard to get into the correct position. Or do you think it's just a learning curve and it'll be ok as-is?
fatboy4211
fatboy4211
Ennis, TX
Im pretty sure its the idiot that keeps popping up in my mirror. hes been following me around lately.
once again....thanks!!
