4BBL Intake & 2BBL Carb?
Tedster100
Chairman of the Bored
For reasons I won't go into I'm pulling my intake and heads to do a little investigating. I was thinking about putting on a new aluminium 4BBL intake so I could upgrade the carb at a later date. Right now I don't want to shell out the cash for a whole new carb and don't want to add another variable to my engine at this time.
Summit has the intake and a new EGR plate that looks like it would fit the bill. Has anyone done this? Would there be any issues?
http://www.summitracing.com/parts/EDL-2121/
http://www.summitracing.com/parts/EDL-8057/
Explorer
Raphine, Virginia
Not saying it's an ideal arrangement, but I did the same thing on my last project to get it running and break in cam since I knew my carb was good. The intake can be had at Advance store sometimes for $100. You still need the 4v to 2v adapter, Mr Gasket makes those and also locally available. I just did away with the carb spacer/EGR plate.
broncnaz
Unless you want the EGR for some reason i would just go with a standard adapter. might want to double check that egr adapter to make sure it even fits a 4v manifold.
I made my own adapter once out of plate steel. Of course that was only used for a short time to work out some bugs.
If you really want to use the 4v manifold I would consider finding a 4v carb on craigslist or something you can usually get them for around $50 While you might not want to add a varible to your engine you are adding a varible any way you look at it with both the intake and a 2v carb. While there's usually little differance in how it runs sometimes 2v carbs and 4v manifolds do run differently.
KyleQ
Holy CRAP that is an expensive intake - quite a few mustangs came with factory 4bbl intakes that can be had for DIRT cheap. (I paid $20 for mine)
Spend that money on a truck avenger - you are going to want the power of going 4 barrel.
Tedster100
Tedster100
Found one on craig's list. Going to look it over tomorrow!
