- Nov 11, 2007
- 8,002
Just to clarify, this is the 4G alternator found on the Ford Explorer serp setup.
Strangely could find no thread specifically on the 4G, many 3G. I had to dig into some of the great RJM tech schematics which I'm not going to bore you with.
OK maybe just one. But it is copyrighted so I'm just supplying the link to his pic.
http://www.grandmarq.net/oldfuelinjection/public/alternator/4G-ALT_wiring.gif
Who uses an alternator idiot light? Nobody right? So to keep it simple:
Hot battery cable type wire off M6-1.0 threaded post to fuseable link to battery plus side. Yes, a metric threaded post on a Bronco. I sourced these wires from WH, comes with fusible link of ginormous proportions. I also sourced some battery/alt/starter cables for F250-350 for later use but not going there this year.
Next, the three control wires out of the s-545 connector on the alternator.
Since I keep it simple, using the RJM diagram the green wire with in my case a red stripe goes to run/hot on the starter solenoid. 20amp inline fuse or fuseable link wire would work. 20A seems excessive, but what do I know.
The next wire is the yellow wire with a white stripe. That jumps over to the M6-10 hot output post.
The last wire which in my case is a white wire with a black stripe, is not used. Seal it as required.
I sourced three junkyard connectors and all of them were flimsy heat damaged. I bought the new connector from summit for $10. https://www.summitracing.com/parts/smp-s545
Done.
Done.
