SteveL
Huge chevy guy
If doing a 4r70 swap what's the difference between a 2wd tranny or 4x4 model?not sure whether using the dana 20 or going atlas. Looking at options.
35s and 4:56. About to swap arbs in.
Another option is 4r70w with manual valve body.
Difference between 2wd and 4wd 4r70w is not really relevant if a D20 is going behind it. You need an adapter either way and you probably should open the trans up no matter what, unless you have personal knowledge of its condition. I personally wouldn't go to the trouble of installing a transmission without rebuilding it first.
I would go 4.88 if I were you.
