I just finished this swap this summer. Wanted to do it 4 yrs ago but after talking to Carl at USShift and their debut for the StandAlone Controller was planned for 6 mo later... I wisely put it off till this year.
You can check out the details on my build thread. Here at post # 329
https://classicbroncos.com/forums/showthread.php?t=278607&page=22
I ran the 4r70 with different doublers and t-cases for 9+ yrs. Loved it until the 6r came out. lol Not one issue with the Baumann Optishift Controller in all those years.
6r gear splits are much better. The 6r can handle several hundred more hp/torque than my 4r can after I built it for 700/700 with 300M shafts and top end clutches.
There are several things I don't like about my setup at this point and hopefully these will get remedied... soon. All USShift controller related.
Potentially it's going to be great. At times it's right, other times it's not great.
What adapters are you planning on using...
The adapters you need for a 6r to a sbf from Performance Automatic is a huge joke. I mean joke... as much as how they are designed as too how much the absolutely terrible advice their tech department has... to cover their poorly designed products. In over 25
years I have never trashed a vendor on this site... but this product deserves it and I am only saying it so when you purchase $600 or 700 dollars worth of adapters from them you can remember reading this and going... he wasn't kidding...
The trans is tall and but it's amazing that's it's not much wider... but if you haven't moved the center point of your front diff over you are more than likely going to have frt DS issues. I had already moved my D60 over to the DS a couple inches several years ago and with 1350 joints I have an 1/8" clearance between the dbl carden joint and the case. I know other guys who have ground the case down for clearance, others have gone with a smaller dia DS... it gets tight fast. The top will come extremely close to your tunnel with only a 1" body lift...no room for flush mount cable shifters unless you have 3" BL.
It's expensive as heck! Controller is about $1300, adapters close to $600+, the TC won't fit (with their adapter) without machine work $100-300, adapter to D20 (same as 205) or Atlas $500 appr, new shifter, used F150 2013 or later 4x4 with 5.0 engine trans seem to be around $1,000. Of course new crossmembers are needed, driveshafts, etc...heck, just the Motorcraft fluid is about $8/qt!
You can run this trans as a full auto so it shifts like a dream. My in town mpg increase almost 15% with it over the 4r. Mainly because I am in a higher gear around town all the time, idling along at 12-1400 rpm without the TC locked of course. Smooth as silk at that rpm with my engine loping (big cam) as I can't lock the TC until I hit 55mph since my cam is kinda radical.
The 4.17 1st gear is great addition. In my case it allowed me to not have to use a doubler anymore which eliminates 6 1/2" of drivetrain length.
Great gearing for off road. I like the 4.17 first gear. I take off in it almost every time around town.... that's with 5.13 gears and 40"s in a 5,000 + lb rig. First gear with the 6r is not like first in a ZF or 435... shifts so smooth you don't feel the shift (barely) from 1-2.
