4r70w and headers
MonsterBIlly
So i am mid way through the swap and my headers are way too close. I need a set of shorty headers to clear the pan. I see a couple different sets on vendor website, but i am wanting know if they need to be bronco specific.
Will most any set of for 302 shorty headers work?
also, the torque converter for the 4r70 has a larger bolt pattern than my c4. i know i need a 164 tooth 28oz imbalance but not sure of the bolt pattern. do one of you guys happen to have a link if you have done the swap.
The Bronco has a narrow frame. The headers need to be Bronco specific if you want them to fit in a Bronco.
67 Halfcab
I tried a couple of different sets. The Bronco Hut shorties worked the best in my case.
The flexplate is the 11.4-11.5" bolt circle(depends on how sloppy they are measuring it) 164 tooth AOD/C4 flexplate. Do not get the C6/E4OD which has all the exact same specs except the offset is slightly different and will bottom out the torque convertor and put excess load on the thrust bearing in the engine. You can get it as a stock replacement piece (mid 80's crown Vic had a 351 option with AOD), or standard 70's C4 except the Bronco C4 with the 10.5" bolt circle so long as it is the 164 tooth version.
PNW
BC Broncos shorty headers fit the 4r70 fine.
markw
Another option is the Mad Dog Headers fenderwell version. Outside the frame. Not sure how they'd work with inner fenders in place, I don't have any on my Bronco.
BanditBronco
I had zero issues with the bronco hut shorties. They are not the nicest headers I have ever seen, they are definitely $300 headers. Nothing a little time and some ceramic coat can't fix though, still the most economical option I would say. My only gripe is that they are gasket flange. In my opinion ball flange are the way to go. I never had any issues with the ball flanges on my long tubes. I had V-Bands welded onto the bronco hut headers and they are better than gaskets but still kinda finicky.
PNW
The Bronco hut shorty's are still 2 and 1/2 inch collector size ??
englewoodcowboy
Lick Creek Restorations
Duff's has reworked their long tubes to work with most transmissions including the AOD/4R family. Give them a call.
BanditBronco
You can get them in 1.5" or 1.625" diameter tube but not sure if they up the collector size when doing so or not. My 1.5" are 2.5" collectors.
PNW
Thought they were still 2.5", thanks.
Not looking to steal the thread but am still looking for shorty's in 1 3/4' or larger dual bolt pattern primaries with 3" or close collectors. Found some 1 3/4" primary 'Stang headers but the port is squished to 1 1/2" so why have larger primaries. Guess it's time to make another set...least they have great kits now.
rcmbronc
Tomah WI
I looked hard and long and was not able to find any. My Mad Dog headers are 1 3/4" but not dual bolt pattern.
Clear Image I was told could make them but the last I talked to him he did not have three phase power at his new shop and could not bend the 1 3/4" yet but that was a bit ago.
http://www.clearimageautomotive.com/performance_headers.php
