4R70W conversion to Small Block Windsor Kit
Fitz24
That's not quite a turn key kit for an Early Bronco. Need a 4x4 model 4r70w or specify 31 spline output shaft. Also need the adapter to bolt up the Dana 20 or what ever TC you're running. Don't forget fluid, cross member, and drive shaft modifications that will be necessary.
