4R70W Crossmember help
Nickm1024cobra
Chicago Burbs
Just installed my 4R70W with adapter from wild horses. They say in the very limited instructions you can modify the crossmember. Attached is a pic on how far back the crossmember will be from the original location. I see no alternative between either fabricated crossmember or cutting the mounts off the frame and rewelding them. Let me know if Im missing anything.
surfer-b
Couple of options, you can mod the original by cutting the back off of the mount that attaches to frame, weld a piece of plate back on that is long enough to reach the original mounting hole in the frame.
Another option is to get a piece of angle and cut it long enough to bolt to the original holes and catch the cross member, this is what I did because I had a piece the right size laying around and it is less work.
