4r70w crossmember incompatible
Jaybr
Just posting this for reference in case anyone runs into the issue in the future. I have James Duff adjustable radius arm drop brackets installed (where on truck when I bought it). I’m in the process of full restore and installing a 4r70. I purchased a crossmember from TBP and when I tried to fit it the JD Bracket is in the way keeping it from dropping down far enough to get bolts in . I’ve ground down the welds as far as I’m comfortable and the passenger side just isn’t going to work. Stock crossmember worked fine so I’ll modify that to work with the AA transmission adapter.
bax
Old Member
I would not have an issue with cutting / grinding the duff bracket flush with the frame. The bronco frame is rounded so the weld should be burned in past the flat of the vertical side of the frame. I think you can make it work if you want to.
Jaybr
Jaybr
I don’t have a problem grinding it flush, and I started that process, however the C channel on the front where the bushing goes in is wider than the frame so if I grind that flush best case I’m thinning it out a lot. I’ll post a pic.
I’m looking at 2 options:
1. modify the stock crossmember and fabricate extended brackets
2. Flip the TBP bracket and drill and tap new frame holes
Leaning toward using the stock bracket, only issue is it’s 2 hours away.
bax
Old Member
Do you have a welder? If so you can cut the plate from the square tubing right where they are welded to each other. Build spacers to move the 4 bolt mounts inboard so they no longer contact the duff mounts. Mount the 4 bolt mounts and spacers. Measure the new length of the square tubing, cut matching angles and tack into place. Remove and weld it up. Paint to match. All good?
Jaybr
Jaybr
I do have a welder, wouldn’t it be a lot easier to cut 1/4” out of the square tubing and weld back together with maybe some bar stock inside to reinforce?
Either way it can be done but I think it will be easier for me to just modify the stock crossmember.
bax
Old Member
Well I was modifying the crossmember. Yes it would be easier to take a 1/2'' out of the square tubing. I say 1/2'' because you will need 1/4'' spacers on each side. Cutting the square stock a 1/2'' in the center will leave you with your mount holes in the middle being off by 1/4'' each way. I cut it off on the ends so you could keep the spacing correct in the center.
