4r70w install notes
E
EricLar80
It made sense when I tried putting it one vs the other and comparing it to the original output shaft since the sleeve is supposed to hold the pin in place; and the snap ring holds the sleeve in place.
Anyway, according to this website:
http://cmeyers.boilerbots.com/bronco_trans.html
It goes like this:
Eric
RustyNutz
Coos Bay
Thanks Eric, feel a little stupid now, I just went downstairs to check it out and although the pin will fit in two different locations, it will only fully insert far enough in one of them to allow the sleeve to go on.
broncokak
Going to be doing this swap over the winter. Subscribed. Thanks for the write up.
nahledge
South Pasadena
Great writeup. I'm currently doing the same swap. Any advice on how to mount the tps or fab a bracket so the optishift can know when to shift. Running and Edelbrock carb and optishift doesn't offer a kit for this carb.
E
EricLar80
I think there are postings out there about that, but since I have EFI, I was able to just tap into the existing TPS.
Eric
