- Oct 8, 2019
- 540
I have a 4r70w out of a 97 Mountaineer that was rebuilt by Lick Creek, with new torque convertor. Installing on a BP306 with new 164t 50oz flex plate. I checked the torque convertor to engine fit before installing flex plate. With the flex plate on, the studs on the torque convertor don't line up perfectly, maybe 1/32-1/16 off so cant get it in by hand. I checked the offset on the convertor to make sure it was seated and had 1/2" to top of studs, so ~1" to face, fairly certain it's fully seated.
I got the trans mated to motor this morning, studs lined up and pulled through when I slowly tightened bellhousing to motor. The thing I'm concerned about is there is no play in the torque convertor once it's mated. I'm pretty sure that is because the studs are so tight in the holes, but second guessing myself.
Should I pull it all apart and maybe drill the flex plate holes a little bigger, or let it ride as is?
