Rem28ga
Newbie
- Apr 12, 2010
- 49
So I did the 4r70w and Np205 swap in my 74 bronco. The dang thing leaks like a sieve between the two. I am constantly adding fluid just to see it run down the face of the transfer case. I have been reading that the adapter between the two is supposed to be wet (no seal on the rear of the trans?) I know my C4 had a rear seal so I assumed this one should too?. How have you guys had success keeping fluid in? How much ATF should be in the transfer case adapter? I must be missing something?? Thanks in advance. My 4r70w is from a 98 explorer and the Np205 is from a 79 Bronco.
