4R70W Need a Rebuild?
pcf_mark
Fellas - I am trying to sort out my controller for my 2000 Explorer 4R70W. I wanted to move my Bronco tonight and assumed it would at least move in drive and reverse without a controller. However when I put it in gear (any gear, forward or reverse) I have to rev the engine to get the truck to move and it only does it after revving and is obviously not putting down any power. The trans fluid is on the bottom of the stick so it is low but I expected it to move.
Is this because the controller is not firing the pressure solenoid to hold the plates etc? Or is my "shifted great when I took it out" transmission in need of a rebuild? Uh.
broncnaz
While no first hand experaince I've heard the it should go into gear with no controller input. I believe you should have reverse and 2nd. Just wont shift. Its probably the low fluid causing the issue. lets hope its not the ran when removed issue.
BanditBronco
You would be surprised how even half a quart low of fluid could cause acceleration slip from a stop. I say add more fluid before you pull the thing for a rebuild. Thats kinda like repainting your whole house cause you scratched the dry wall moving a couch in...
Amac70
ME
i would top off your fluid also mine is really finicky about having the right level of fluid in it.
Add fluid first.
Without a controller it will drive forward only in 2nd gear and have no engine braking. You will also have reverse. It will drop into gear hard as default is full line pressure. I backed mine out of the shop and drove around the block trying to fugure what was wrong before I realized I forgot to plug the transmission in. Yes it will drive with zero wires attached.
pcf_mark
pcf_mark
I hope it is the fluid level. It was barely on the stick but it barely moved when I revved the engine. It did "clunk" like it was going into gear as I was expecting. Felt more like an old C4 with tired seals....
pcf_mark
pcf_mark
Well I filled up to the high mark while running. It goes into reverse soft but it goes in. Not really drive or any lower gears. When shifting from drive or any lower gears to reverse or park I sometimes get a really nasty mechanical sound. Like a metal baseball card in spokes.
I've heard these transmission were near bulletproof. Guess not.
I have rebuilt C4, 700R4, TH400 so I guess 4R70W is next. Hopefully ViperWolf jumps in with any tech tips or parts lists.
ZOSO
I watched that whole series. It's pretty hard to do but after awhile you get used to it.
pcf_mark
pcf_mark
This is going to sound like a total noob move. My t-case shifter is contacting the floor where it passes through the floor. It goes in 2W High just barely. Then when the engine engages it can dislodged it. If I keep the weight of my hand on it I was able to reverse out of the garage and back in without any real issues. Drive as slow engaing but after letting it fully warm up I added two more quarts of ATF. So I MAY be out of the rebuild thread.
Now If I can only get my Megasquirt to talk to my Microsquirt trans controller.
