4R70W /NP205 swap
SLC
Anyone have time to get a measurement of location of transfercase shifter hole in floor board. ( my body doesn’t have any holes). Thanks in advance, I appreciate all of you guys help especially Nvrstuck…thanks
1973bronco1973
I used the factory location but extended a little to the front and back. The shifter I used was the stock np205 shifter and I heated it and bent it just a little for alignment. This is with a 3” body lift. I had to adjust the length of the shift rod from the shifter to the tcase.
fordguy
Will u have to cut tail shaft for the NP205
1973bronco1973
I used a 4r70 out of an awd explorer. No mods to the tail shaft. You do need to cut/die-grind the tail housing for clearance of the shift mechanism on the 205. Just use the 205 gasket as a template.
In addition to the original question, I did not use the trans mount. My “transmission mount” is only off the rear of the 205. I figured the 205 was too heavy for the back of the 4r70 without supporting the 205.
I recently completed the rubicon trail and didn’t have any issues without the transmission mount being used.
fordguy
I abandoned my original plan to use the AWD and NP 204 because I could not come up with a mount I liked for the 205. Seems the vendors would come up with one.
S
SLC
Thanks for your reply I’m going to try to get it close without butchering the floor up . I’m going with a console floor shifter so I’ll be cutting another hole in floor for cable to go through . Any pictures would be a help .Thanks again
