BruiserOutdoors
- Aug 22, 2013
- 859
Installed a 4r70w that was a fresh bench build with the AA Dana 20 adapter with a a Quick Shift 4 controller. The transmission was built in 2020 and installed in 2024. It would "neutral drop" on occasion from a dead stop. I ended up getting the OK from the transmission builder to just "drive it" and see if it would work itself out. It ended up losing 3rd and 4th after 13 miles of test runs. It threw slipping error codes at max line pressure. Took it back to the transmission builder and he rebuilt it and figured it was a valve body issue. I have an additional 120 miles on it now and it has "neutral dropped" 4 or 5 times, usually at more than 1/4 throttle. It no longer seems to happen from a stop like it used to.
Stock explorer dipstick and tube. Fluid level seems good but I need to measure and verify the dipstick length.
[When I say "neutral drop" I mean the transmission drops out of gear and the engine revs up]. No error codes this time around.
Any guidance would be appreciated. Valve body issue? Controller issue?
