firehawk
Look for the forward clutch pressure tap. Marked "FWD", third pressure tap back on the passenger side. It is standard pipe threads. Put a pressure gauge on there. A 0-300 PSI gauges will do. IF it has 0 PSI and wants to move, clutch is welded. If there is pressure there is an issue in the valve body.
The fact it wants to nuetral out when the fluid is low makes me feel the clutch isn't welded. Just low on fluid and couldn't build the pressure to apply the clutch. If it were welded it would want to drive even low on oil unless the convertor was so drained it couldn't provide any force. Only a few quarts low should have enough oil in the convertor for some driving force into the trans.
Do I check it in park or in gear?
