Thecrazyone
- Sep 8, 2007
- 84
I can share this tidbit right now.
Save the following from your old harness
Pigtails for Front side markers
Pigtail for the Headlight Switch
Pigtail for the wiper switch (try to save it all the way to the wiper motor!!)
Pigtail for the Ignition switch
Pigtail for the column
Gage Power connectors (hooks to the cvr and the fuel oil and temp)
Alternator to Regulator Harness and the thick black with yellow stripe wire if you want to reuse your amp meeter (you'll have to cut out a bunch of wires from around it)
If you have a 2nd tank you will need to add a wire in the rear harness for it
If you have a windshield washer motor you will need to add wires for that
I can take some pictures, but my install will vary slightly as I did an Ignition upgrade (pertronix and Jacobs) at the time. I would highly recommend you ditch the points if you still have them.
WOW! If you have to save all that from your existing harness, you might as well not buy the ebay one and stick what you already have. It would be cheaper.
I rather have a full wiring harness that I know is new and complete. Not just replace some of it and still leave you with old wiring.
