5.0 EFI Backfire/explosion issues
joelozano
I recently installed an efi 5.0 from a 91 Mustang and I'm running the stock three speed. I'm having backfire/explosion issues when I hit the gas on whatever gear I'm in. Need help please.
sp71eb
North Liberty, Ia
Alot of people have been having these issues...including me. Mine was the incorrect maf sensor. A few things to check are,
What MAF are you using.
Check for burnt plug wires.
Check fuel pressure.
As stated, check your timing.
Check your TPS.
ENDLIFE
I've been having this same issue, but it's intermittent. At a stoplight when I hit the gas to go through it runs like total crap until I hit the gas a little more, and then eventually the check engine light will come on. The only code it throws that's not normal is a code 41, it says it's the O2 sensor for the passenger side, I do have a few small exhaust leaks, but I don't know if there big enough to fault the O2 sensor.
Has anyone had and solved this problem?
Check your TPS.
Still waiting to hear back about these questions.
