FrankSG
Guys
I just finished the build on my 5.0L H.O. After setting all of the usual timing, etc... It started just fine, but after it reached operating temperature it started to backfire, and had very little power.
One thing that did happen was that the O2 sensor connection was semi meted on the headers. After inspecting the wires I rebuilt the connector with a spare that I had.
Would a faulty connection / damaged sensor be the root of the problem? I know that seems like the obvious choice, but I wanted to see if there could be anything else I am missing.
How could I check the sensor and connection to the computer?
Here are the codes I received during KOKE:
327 EVP/EPT below min. Voltage
552 Air management circuit failure
565 canister purge, solenoid circuit fault
556 fuel pump relay primary circuit fault
(It has no EGR)
What does most of the mean or which ones have something that needs addressed?
Thanks,
Frank
(It has no EGR)
Thanks,
Frank
