5.0 EFI donor ?
Tiko433
Bolivia, North Carolina
If I'm looking to do a 5.0 EFI swap what vehicles should I consider ?
I know the Munsang and Eplorer are popular. What about a T Bird ? Can I just look for any 5.0 EFI ... I know to look for the Mass Air set up .
If I don't get the whole vehicle , get all I can
For guys that have been down this road before , any advise
Broncos n' VWs
The Mustang is the easiest and most complete swap, especially if you are new to this type of project. Most info available online (including this community, which is your best source) is geared toward the MAF Mustang. I have tons of info that I have saved over the years on this swap. The best thing to do is read up as much as you can. It'll help your understanding as to which direction you should pursue for your setup. If you want the info I have, PM me your email and I can email you what I have.
Timmy390
Conway, AR
I can only speak to the 91-93 T-birds. They're wired just like the 94-95 Stangs but for a couple pins. The Stangs have built in fan control where the T-birds didn't. The T-Bird has some ride control stuff added too.
Here is a link comparing the 2
http://forums.tccoa.com/8-engine-5-0l-5-8l/69247-94-95-mustang-gt-manual-ecm-91-93-mn12.html
You don't have to go Mass Air you can run a Speed Density setup. I took a speed density setup from a van and converted it to Mass Air SN95 Stang setup.
Tim
doghows72
I did this setup in my first Bronco. Its an 88 T-Bird motor and trans.
