Just a reminder that you won't be able to start new posts or reply to existings posts in the Archive forum.
DON'T run your old balancer! Your old engine ran with a 28.2 oz. imbalance, while the 85' (an I have been told possibly 83') and newer engines run with a 50 oz. ombalance. With the age of the rubber in your balancer, it may shred at some point(when, who knows). Go to the junk yard, and get a balancer from any 85' or later 302 to be safe.
[quote author=Explore74 link=board=5;threadid=12521;start=0#93359 date=1040447492]<br>DON'T run your old balancer! Your old engine ran with a 28.2 oz. imbalance, while the 85' (an I have been told possibly 83') and newer engines run with a 50 oz. ombalance. With the age of the rubber in your balancer, it may shred at some point(when, who knows). Go to the junk yard, and get a balancer from any 85' or later 302 to be safe.<br>[/quote]I disagree! The engine is balanced with the flex plate or flywheel not the dampner! Besides if he's using the Bronco assories he needs the 3 bolt dampner.
rulebreaker, I never said that the balancer was what balanced the engine. But, the balancer offsets the harmonics set up by the engine. If you take a 30 year old balancer and ask it to do what amounts to more work, you are asking for trouble. I have seen main bearings get hammered out of their saddles in less than 100 miles when the rubber in the balancer failed.
[quote author=Explore74 link=board=5;threadid=12521;start=0#93470 date=1040506714]<br>rulebreaker, I never said that the balancer was what balanced the engine. But, the balancer offsets the harmonics set up by the engine. If you take a 30 year old balancer and ask it to do what amounts to more work, you are asking for trouble. I have seen main bearings get hammered out of their saddles in less than 100 miles when the rubber in the balancer failed.<br>[/quote]Couldn't he put a new Bronco harmonic balancer on it so that he could use his original Bronco accessories, if that is what he is trying to do?
