5.0 Radiator Help
mike mac
Daly City, CA
I've asked may Q's on this site about cooling and I still can't get it right. So hears what I got, 5.0 out of a '95 f150 with stock rad.. I had my rad. reworked to fit the conversion and keep serp. system. I put in a 14" elect. pusher fan in and it is like a fart in a wind storm. So the first thing I hear is to run a clutch fan but there is no room. So I added a 17"flex fan and now it runs at 160 deg but sounds like an f@#*in jet turbine. So I'm back to square one. I'm debating buying Duff's 5.0 conversion alum. rad.. Also I was thinking of leaving the 14'" pusher and adding a 14" puller to force air through. Can anyone help me or at least let me know how retarded I am. Obviously not a mechanic but I do my best. thanks.
Viperwolf1
electron whisperer
A small electric fan is not going to cut it and pushers don't work well either. You're lucky that the flex fan worked so well. You might try a big electric puller but you probably need a good 4 1/2 inches between the radiator and wp pulley. You can also find flex fans with narrower blades that may be quieter. Personnally I'd be happy if mine ran at 160 no matter how much noise it made.
67EB_in_619
San Diego
mike mac
mike mac
Daly City, CA
I'm very happy about the temp. but it is really loud. would a shroud quiet it down? Also if I go without a shroud will it kick up dust?
ransil
I cut my core support and move the radiator forward. Then run the stock 5.0 fan .
eds66bronco
Essex, Vermont
you should always use a shroud. otherwise, all you are doing is throwing air off the end of the fan and circulating hot engine bay air. the shroud creates suction through the rad, drawing in cool air from outside the engine bay. this will also quiet things down quite a bit. I tried the taurus fan route but still didn't have enough room in front of the motor to make it fit without core support mods so i went with a solid fan.
