Use the pitman arm that goes to the drag link you are using. Either will fit the steering gearbox, but you need to match the taper for the draglink.
As I recall, the early linkage has the larger tapered hole (but for some reason I get that mixed up without loking sometimes even after all these years!). ?:?
