'66 Brake master conversion
bigjhoov
nobody
Anyone converted from a single res m/c to a dual res m/c? How involved? What additional parts are needed? Proportioning valve?
73stallion
Eugene, OR
i'm about to do this on unclebap's truck. you'll need to run a second line down to the frame, remove the rear line from the front line block bolted to the frame, cap off that hole where that line came from, and tie the second line you installed into the rear brake line. just remember, the large reservoir is for the front and the small is for the rear. hook up the lines to the MC accordingly.
73stallion
Eugene, OR
no, forgot about that. it's a pressure switch on the MC. you can either put a switch on the pedal or put a "t" in one of the lines and screw it in the "t". the pressure will still activate it.
bigjhoov
bigjhoov
nobody
Is there much benifit to doing this conversion? Any other suggestions.
bigjhoov
bigjhoov
nobody
No, no benefits or no suggestions. I don't plan on disk conversion, too $$$.
broncnaz
I'm with SteveL on this. The benefits are you will still have some braking capibility if something fails. If there was no benefit to it why did the manufacturer go to dual res types?
feitctaj
FNG
Group W Bench
I thought they were forced to use the dual master cyl.
It will help save your ass if a wheel cyl fails. I came down a road and had this happen, with the rear wheels locked up I only hit that dam car at 5 miles an hour unstead of 25.
66horse
For the brake lights, I found myself a later model pedal that had the mount for the brake light switch on it. Put the in, ran the wires that used to go the pressure switch to that and never looked back.
For the brake lines, it was explained above but in short, right now the single line goes to a tee and from there the lines go front and back. You will need to take out that tee and hook up on line from the dual cylinder to each the front and back.
bigjhoov
bigjhoov
nobody
Okay, I've got the dual res mounted up, I've got the new brake light switch mounted, I got a problem though.....
Why are the holes for the brake lines so friggin BIG? Is there an adapter or something I need to use 3/16 steel lines. Also, Why are they different sizes? Stop laughing!
73stallion
Eugene, OR
a lot of times you need adapter fittings. take your mc down to the part store and have them get you the fittings to screw the lines into. shouldn't cost more than about 3 bucks.
