66 windshield washer pump location
TPTFPS68
Mexico, Mo
Can someone post a pic of where the w/s washer pump mounts on a 66, and the hose layout from the bag to the pump/pump to hood nozzles?
I can't locate what color the wires are that go to the washer pump button on the dash.......any help would be much appreciated!
Posted up to your wire questions, but as far as the pump itself goes, do you have any suspicious looking holes in your driver's side wheel well under the hood?
The washer bag hangs there on the front face on a hooked bracket (got that already?) and I can't remember where the pump goes exactly.
Just posting up so I can see what answers you get and to put you back up to the top.
Good luck.
TPTFPS68
TPTFPS68
Mexico, Mo
Thanks Paul! I did figure out where the pump mounts. ( in front of the L wheelwell on the inner fender). The pump looks like a one wire hookup, but I don't have anything to go off of. ( basket case build). I have a very good original 66 harness that I'm working with but can't figure out what color wire powers the pump button, etc.
Major Tom
the ONE wire connection on my original 66 appears to be black with a silver stripe
Can't tell you how it's routed, but it can only go one place. If it's powering the pump, it's got to go to one side of your dash switch.
The second connection on the motor/pump itself goes to ground, and the second connection to the pump switch will get power from the harness.
Not sure where it would have been sourced on a '66, but on later models it was sharing a splice with wires from the radio and backup light fuse (F2).
Major Tom
it is a single wire that runs along the fender alongside the other wire harness and enters the firewall through a single gromet
66BlueGoose
Mine is the same as Paul listed, here are some pictures. Note that i have replacement bag, the original one is blue and is wider and shorter.
Picture one - pump and bag
Picture two - wire on inner fender
Picture three - hoses on hood
