Needa... if more action doesn't happen this week from Lee, I may take you up on your offer.
Here is a list of items that need to be done:
- blow out, clean and anchor all A/C & heater hoses.
- Build a bracket to hold the coil & mount it.
- Hook up all the engine related electrical.
- Install Air cleaner (billet oval arrives this week to replace the chromed stocker)
- Hook up the headlights/harness/park lights
- mount the wire harness to the back... hook up the taillights, license light and install 3rd brake light
- anchor the free end of the emergency brake cable housing... too spongy
- Complete the install of the accelerator cable/pedal assembly
- Clean up and spot paint the hood latch area on the grille
- Attach the hoses for the radiator and overflow
- Plumb the washer bottle/lines/electrical
- Wire the reverse light switch and brake light switch on the shifter and brake distribution block.... respectively
- Wire the main and reserve senders, pumps and switch to the stock dash switch
- prime the engine
- drill roll bar upper to mount the shoulder belts & mount the retractors below.
- install the fuse box & glove box... and mount the wire harness under the dash
- wire up the interior map lights and aux lights for the rear to the "cargo" switch on the dash
- hook up the wiper wiring (wires already run)
- measure the rear interior qtr panels, get the stainless cut and bent so the the top can be locked down solid.
- Remove stock tire carrier, weld in holes on rear corner and fill the latch holes on the tailgate... repaint... also fix where the damn forklift dented the tailgate
- Install "Nick's Gas assist spare tire carrier"
- Replace old crummy chrome bumpers with brand new chrome ones
- Install polished Bronco nerf bars
- Install Glass, seals and trim on windows and doors
- Fix remote control drivers side rear view mirror
- Install brains for power windows and locks
- Take over to alignment shop for alignment, mufflers and exhaust system
- Install center console, stereo, components, speakers
- Wire up the aux lights (headlight rings, rock lights, fogs)
- Install courtesy light switches & wire them up
AND
DRIVE THE HELL OUT OF IT
Did I miss anything? I know that there will be gremlins to track down and kill... but this is the list that comes to mind.
