69 Build Up Progress F150 axles out Dana 60's going in updated pics 9/25/05
Tgure
Tgure
Phoenix
bluebroncodrive said:
I got a question how are you connecting the bike fuel doors to the fuel tank. any pics?
Because I moved the fuel doors out further than stock I have some fabbing to do to the tub to make room for the filler necks, then once the tub is back on the frame I will then figure out what I will use to connect to the tanks. I will update pics of that once I get it done, but it will be some time before I get to that part. I needed to get the tank bungs welded in before painting etc. ;D
Tgure
Tgure
Phoenix
Well being laid off has put a wrench in the bronco build. So things been pretty much on hold. I do have an interview tomorrow so after 2 months of being out of work and 200+ resumes maybe I can land a job. :p
Anyway I sold my full width big bearing 9" and HPD44 so I could buy a rear 60 and a front HPD44HD to swap into my F250 so I could pull the HP60 out of it.
Well in AZ 4x4 axles are rare and expensive so after looking for several weeks I finally found a set for the reasonable price of $796 :'( . So yesterday afternoon I pulled the 60 out and put the HD 44 in the F250 and then today started cleaning up the rear 60 and cutting off the shock mounts and 5/8" thick spring perches :eek: so I can weld on new spring perches to bolt into the bronco.
Should be able to mock up the rear and weld on the perches tomorrow and just waiting for radius arm wedges to arrive for the front then I can get that mocked up and welded. Man it feels like I just did all this not to long ago %) . Oh well now I will have a pretty beefy drivetrain. ;D
crawln68
Glad you finally found some axles for the F-250. I know you said that you are waiting to receive the new wedges so you can start grinding, but have you given any thought to building a 3 or 4 link front suspension? After I did all of that grinding on my wedges and fabbing, I wish that I had done a 3 or 4 link instead. I think it would have been less work with better results. Just a thought. ;D
Tgure
Tgure
Phoenix
Well I thought about it but I already have the Cage arms so thought I would just use them and I am not sure a 3 or 4 link would give me any additional benefit. But who knows I may start all over again the way things are going so far :p
