- Mar 8, 2007
- 81,983
A milestone!
Hmm, where'd that grease on your hands come from? I don't see any on the Bronco...![]()
lol no grease allowed..
A milestone!
Thank you!Looking so dam good.. good job
Glock 20sf.getting her done man.. what Glock is that?![]()
^^^Standard equipment for any EB engine compartment^^^Glock 20sf.![]()
Fuel tank wired up & installed, solo install was interesting to say the least.
Thank you. That's exactly how you have to install it. The necks coming out of the tank make it too wide just to raise it up straight, so you have to raise it up at an angle & use the hoses to somewhat guide it over the frame rail. Also make sure to grab & feed the fuel lines & wiring over the cross member when the tank is partially up or they will pinch against cross member.Awesome build, man. I’m getting ready to install an M1A1 in my rig. I’m curious, did you put the filler and vent hoses on first and fish them over the top of the frame rail? Unless you have a big body lift, I don’t see how it’s possible to tighten the hose clamps at the tank end after the fact.
Was that a "new" dead blow hammer at the start of your build?Ron Davis placed to measure clearance, HD coil buckets installed, & MSD is sitting in its new home.
I actually chuckled at this haha. That hammer has helped me build about a dozen vehicles over the years & I’ve been reduced to using the other side.Was that a "new" dead blow hammer at the start of your build?
