7100's front, what rear?
Bronco69Sport
Upper MI
I have the 14" 7100's for the front, but I am looking for possibly the 5100's for the rear. Are inboard mounts that much better for flex? And if so, I am running a 4.5" lift on 37's What would the guru's recommendations be for a rear suspension. Stock location size? or inboard size if they flex much better inboard? Thanks.
garberz
Bronco Influencer
Conejo Valley, Ca.
With an inboard mount setup you get lots of travel with a shorter shock. The shocks are mounted at a 45 degree angle, they move at a 2:1 ratio. If your suspension cycles 12", your shocks only move 6". To get full travel in the rear, the stock location won't allow for long enough shocks. Then your flex will be limited, The Inboard hoop is a simple solution. You'll need to flex the rear and get some measurements to see what length shocks.
needabronco
Prescott/Farmington
If you've got 7100's in the front, why not use 7100's in the rear? I'm planning to mount some 12" travel short body's in the rear of mine. I've got a 1" body lift and a 3.5" suspension lift. My upper mounts are going to be custom made but look something similar to the shock jock that WH sells. The system I'm copying fits this same shock. I would assume that you could easily mount these in an inboard location.
BTW, Lee at raceshock.com, is the man for Bilstiens. He hooked me up very well and was very easy to deal with. Mention your from here also...
