'72 backup light switch location?
thetmaxx
I'm helping my brother install a painless harness into his '72 bronco that has been completly rebuilt from the frame up. basicly we figured out where the neutral saftey switch is, on the colum. This was never hooked up before, and didn't work, nor did his reverse lamps, and as far as we can see there is no switch anywhere that would have been for the backup lamps. the painless harness has the wires for it going to the transmission, which is a c4 auto. I can only find one switch on tom's bronco parts, that has a bracket that looks like it goes around the colum, but i assume thats for a 3 on the tree?
I'm guessing there should be a seperate switch that goes to the trans linkage or something. I really apreciate any help you can give me, and we are not looking to just put a switch on the dash, he wants these to be working the way they should weather by the origional switch, or something we can build to work OEM.
Thanks guys!!!
BlackHorse
Since you have a C4 the neutral saftey and back up lights are normally located in the same switch. 4 wires 2 for back up and 2 for NSS. The manual 3 speed would have the back up switch on the column. The C4 switch is mounted to the side of the trans.
One thing stricks me as odd. You say the NSS is on the column. Stock column? Only pre 73 Bajas would have the NSS there. Many after market columns locate the NSS/back up switch on the column. Anyway you will find most vendors advertise the switch as the NSS only but it is also the back up light switch.
Welcome!
T
thetmaxx
Actually I have been refrencing this site for about a year now reading about different stuff, as we built the truck, there is such a wealth of info i've never had to post.
anyways, it seems to be a stock colum, he just replaced the Turn signal switch, and it was all factory. however when you have a vehicle roaming the earth for 34 years there is no telling what has been swapped out!! it is possible this could have been swaped out for the baja colum you speak of. it is a colum shifter if that helps? just incase it helps, it's a bornco sport...
the nss is operated but a little lever that pokes out the top of the colum, it has the facotry wires, red/black coming in and out. those make contact in park and neutral, but that switch also had two more terminals that are cut off, but those only contact when the switch is slid over further than park, so that doesn't make sense.
it is a long rectangular switch, with a round peg like slider, is scews to the colum, and has elongated holes for adjustment. when i over hauled the trans there was a temp sensor screwed into one of the preasure tap ports, it only had one wire connection, so it couldn't have been for the backup lights. also when i was looking at the trans mounted nss/backup lights for various years it appeared that the linkage on the trans would not be able to clear the switch had one been on there. but i would also agree it should be on the trans linkage. i'll go look at the sensors for the c4, and see if i can rember why they might not have worked...
also another strange thing is that the painless harness did not have wires in it for the nss. so i'm wondering if this is supposed to be a manual trans harness. i told my borther i could fix that easy enough, but we are almost thinking about forgettign nss, and readjusting the nss switch so it operates the reverse lights... shady, but it would probably work...
T
thetmaxx
after a few minutes of looking on bronco grave yard, toms bronco parts, and other sites, i've found they only list a trans mounted nss for 73+ i can only find a 70-73 from ford mustang parts sites. but i remember some reason this wasnt going to work... i'll have to look at this trans again tonight.
i find it odd that it is so hard to find information about this part in this model year. i can only imagine there are a whole fleet of broncos out there now that have just bypassed this switch, because people don't want to fix it!! crazy sob's! LOL
it didn't work before the overhaul, and my brother would accidently start it in gear a lot. it really is a saftey hazard. anyways, thanks for the help if you guys can confirm what is actually supposed to be on this thing!!
T
thetmaxx
Thanks to black horse!!!
I think I figured out what is going on... I browsed the site a little more, and found a good picture of the Transmission Range sensor (sorry thats what we call the nss on the side of the tranny at ford) on the c4 with the linkage and all, so i was looking at ours, and noticed the linkage is different making it so it would bind on the TR sensor in park. Then I remembered black horse saying it could be after market, and then i remember the truck having a clutch pedal mount, and stoper bumper!!! I think it was a manual at one time. I think this funky linkage, and the steering column are either after market, or other ford parts that have been adapted for the auto trans. in the diagram i drew below, you can see how our linkage differs from the factory... so i'll have my brother trim his down so it will clear the bolt, and order this TR sensor. I think it will work beautifully!!!
Hopefully no one else runs into this headache of aftermarket conversions, but knowing old vehicles, i'm sure they will...
Thanks again!
BigSwede
Baltimore, Maryland
My reverse lights came on and have been on since I started driving her. Could it be a bad/stuck switch? It doesn't bother me at all, but looks goofy and can be annoying for those following me. Which side of the tranny is this switch mounted?
